So my old shaft was bad replaced it filled it while lifted so probably did too much, Caused my new shaft to come out i am guessing do to pressure from overfilling. Well my new half shaft driver side just came out again part way and leaking a little is it possible that it still had to much fluid in it? I didn't drain it completely to check the level, I just release the fill plug while on level ground.
So question, been driving it away but was hard on it higher RPM longer time on my way home today, and notice it dripped a little and the shaft clip isnt in there tight
