1 - 4 of 4 Posts
Had the head replaced on my 03 2.0 spi because of a dropped valve seat at 138000 miles. Now its using oil, which I never had a problem before. What do you guys think it could be. Thanks.
How bad is it would be the first question I think of.
Second would whether you've looked at the spark plug to see if it's burning oil in the cyl. that dropped the seat.
Piston/ring/cylinder wall damage can vary from minor to catastrophic when a valve seat drop happens, some who thought it was minor found a broken piston on further investigation.
Minor oil usage & running fine otherwise, you may be able to live with the damage for quite a while - if it's major there's a good chance the damage evaluation missed something.
Cleaning out the intake & exh. thoroughly is part of the repair that's necessary, otherwise crud left in there can do damage afterwards.
1 - 4 of 4 Posts
