I bought my son this 2003 Focus Se Sedan 2.3L a few weeks ago. It had a seized alternator, the ignition was hard to turn and you could remove the key in any position. The dash had a lil quirk going as in the warning indicator lights would stay on very dim and flicker with the car turned off and the key removed. I figured maybe after I resolved the alternator and the ignition problem it might be fixed but no luck...what I have done to the car so far. Replaced alternator(Brand new and had it tested before and after I installed it, Replaced ignition lock cylinder(brand new) Replaced positive battery Terminal, Replaced 175amp mega fuse between the alternator and the starter, I have checked the connections to the alternator and the ignition a few times and I cleaned the ground battery terminal. The car starts up and runs does sound a lil like a lawn mower but the flex pipe has a hole so I kind of expected that. Can anyone point me in the right direction? I found plenty of post online but none of them are really the same symptoms.[boxface]
