Hi all
I've parked my 2002 SVT (105K miles) for the past couple of years, taking it out every other month or for a short drive. Just prior to parking I changed the oil. Timing belt and rebuilt head where done less than 10K miles prior. Coil is an MSD and has been on for 50K miles. It's been about six months since I last drove.
With a jump, the car will crank but not fire.
I'll be checking spark plugs today, will inspect for deposits and check spark by removing a plug grounding the side of it and crank engine. (is that correct?)
fuel cutoff valve is down , i put 2 gallons in
ocdb says no dtc codes
also on cranking engine fired but not for long
it's also warmer 70 vs 60
with jump it 13+ volts
battery alone 12.2
fuses 8 &12 are good
How do I check for fuel delivery?
What else to check?
thanks!
More info on car: http://svtf4243.com/mods_p.html
battery alone 12.2
What else to check?
thanks!
