Hello, vehicle is a 2002 ZX3, 5spd, 97k.
I have recently been getting a P401 code but I do not think it relates to this issue, but I'm mentioning it because I could be wrong.
The other day I was driving home and noticed a sort of lag feeling when I let off the gas when cruising. When I got to my street I pushed in the clutch to coast and it immediately died. It would start if I pumped the gas and had to continue holding the throttle to keep it running. Drove it up the street fine with no coasting. No check engine light.
I did some research and found people mentioning DPFE, IAC, MAF, TPS, vacuum leaks, collapsed PCV hose among other things. I checked and sure enough the PCV hose was collapsed so I made a new one out of some fuel hose and a generic vacuum elbow from Autozone. Started right up, hit about 1300rpm and settled to about 800 or so like usual.
Yesterday I was driving and felt the same lag suddenly. Sure enough, same thing. Had to keep throttle input to stay running, fun to do in traffic with a 5spd. I continued to drive like nothing was wrong for another hour on the interstate to my friends house, then made the 2hr trip back home. Ran fine as long as I maintained throttle input.
Checked my replacement hose while running with a friend and it seemed fine. I tried replacing the DPFE, IAC, TPS, and cleaned the MAF. No change other than IAC. I tried each one at a time, since they made no difference I boxed them up and plan to return them. After replacing the IAC, if I could get it running pumping the gas, the idle would soar to 3000rpm then slowly settle down and then die, all without any throttle input minus what was needed to get it started. I put the original back on and am now back at square one.
I'm not sure what to make of the IAC. Possibly a bad one? Autozone is the only place I could get one on a Saturday afternoon so it's possible. If not, I'm on to fuel delivery. The fuel filter is about a year old. It doesn't seem like there is any easy way to diagnose a fuel delivery issue without a scanner. I have a pressure gauge, but no where to hook it up to.
Any ideas? I'm stumped and would hate to drop the tank and have no improvement! Thanks in advance.
