Hi everyone. First off I'd like to say thank you all I've been a non member reader for a little while and I've taken some of all your helpful advice on regular maintenance. Now, this will be sort of a rant but I'd like to give as much info as I can at once.
I've searched but I guess i am a dunce
I drive an 02 svt. It doesnt matter if it's running cold or warm, while I drive my car feels like it "snaps" out of alignment. It may happen once or back to back and I get in this inescapable rut of correcting for it, then it snaps back, and I'm forced to straighten back out the wheelquickly but then it snaps back out etc... And I'm all over the road. This happens more when I'm on straight and lumpy roads and/ or just turning left. Although even on perfect paved road, and occasionally turning right as well.So I think I've narrowed it down to the right side of the vehicle.
It's been gradually getting worse the last 2 months. But has been an issue since a few oil changes before that. This month I've put in new stock front struts, springs, top mounts, sway bay endlinks up front(moog), on both sides...also had drivers side wheel bearing/hub replaced. They only did one side even tho I brought both. did a poly rear engine mount and new stock rear sway bar( would have done shocks n springs too but some bolt > snapped socket) with poly bushings.
The addition ofthe bar seemed to solve the issue for max one day then it was back to , ahem, "normal" again. Also I've had an alignment and the tires on the back are new. I've been to a local mechanic n he said seems like an alignment issue before I said anything that was done.
Time for me is scarce n I have minimal tools what can I do? Try and look for something loose? Any direction where to look would be appreciated. I'll have to park it and borrow a car if need be if a fix will hit my wallet. And it seems like that's the way I'm going with my svtf
Another issue I've been having is on cold driving my car going over bumps kinda goes wum wum wum (sorry lol) while bouncing slightly or sometimes signifigantly after hitting it. Same for dips in the road, accelerating and then letting off, or steppin on the clutch to shift gears, or breaking. It does it warm too but it's been cold out so getting worse. Today it did it while just cruzing in first to a stoplight in the morning. What can I do?
I know I've asked a lot but I don't know where else to turn n i need a fix for my dd so I wanna ask some people that know the focus. Thanks again ahead of time.[wrenchin]
