1 - 9 of 9 Posts
I have high beam but no fog or low.
Could it be the switch?
What is the color code for the wire so that can I test the wires coming to the harness?
thanks
Vince your Moderator
^This.
There are 6 IIRC
could be switch, fuse, or ignition switch.
Or a relay.
Been there done that.
I checked the fuses they're all good.
One thing I forgot to mention, I have to remove the light switch from the harness otherwise the parking lights stays on even when I remove the keys from the ignition.
How do I test the relay and the ignition switch? (don't really know what they look like or where they are located)
you need the wiring schematic to make sure all the positive wires are where they are upposed to be. easy test for relay swap it with the a known good relay. and see if that fixes it.
1 - 9 of 9 Posts
