1 - 2 of 2 Posts
Looks as if the bag dash cover has been removed before and is now not seated well. Can I go to salvage yard and get one and get it to lay flat or once it gets opened it wont go back right?
Quite likely you can. Bear in mind that removing that cover involves more than just prying it up. There are two gold colored bolts (8mm I believe) holding brackets attached to the rear of the airbag cover, at least on the 02 SVT and the 05 ST into which I swapped the SVT dash. However, read these, which mention clips instead of bolts:
http://www.ehow.com/how_6170211_remove-dash-ford-focus.html
http://www.ehow.com/how_6022407_remove-dash-2001-ford-focus.html
You can also probably find how-tos here (FF) and on FJ. Good luck.
1 - 2 of 2 Posts
