1 - 8 of 8 Posts
Hey guys, got an odd problem and seeing if anyone has ideas. I've got an 01 ZX3 that has recently developed a miss under acceleration, but only around 3-4k RPM. Only when warm, the problem isn't there when I first start the car. No noob light. I've swapped the coil, replaced wires & plugs with no improvement. Also I've changed the fuel filter just in case, but nothing. At this point I'm thinking it may be the crank sensor. I pulled it and, externally at least, it looks ok. I would normally think fuel since ignition has all been swapped but the interesting thing is, if I have enough power I can 'punch through' and once I get over that RPM range it runs fine again. It just sucks because I can't do it with a 350k motor in fifth gear, and it's pretty jarring/annoying accelerating with a stutter.
Have you checked the coil harness? Well known for developing tiny cracks right at the plug where they're hard to see. Mine ran weird for a few weeks before ever throwing a code, and like yours it would only do it under load.
What on earth are you doing at 4000 rpm and in 5th gear? Thinking you are speeding a bit there.
That wasn't fifth gear. You can clearly see the upshift indicator light at the bottom of the tach. lol
Did not watch the link, only read the post, he clearly states it.
lol back atcha...............
Thanks for the suggestion Leora, I'm planning to check into that as well. I mentioned fifth because I can't really get past it in fifth, but can in 3rd and 4th, and videoed that just to help show that it's not a fuel delivery problem in 3rd iirc. I just get to that speed in fifth (~85) when I'm cruising the interstate...in Mexico of course, but it irks me in other gears knowing that something isn't right
The fact that you can get past it in any gear suggests it's likely not the coil harness, but it's an easy enough check and a known problem area on these cars.
Did you scan it for pending codes?
Discussion Starter #8
Fixed. There were no pending codes, I swapped the crank sensor for a spare used one and it's not been stupid since, including the 7-hour trip to the OBX I took this week :)
1 - 8 of 8 Posts
