Hello all..I am new to the forum but I just purchased a 01 Ford Focus SE 5 speed Manuel....I will be posting a lot if different questions on here. Seems like I am finding a lot more wrong with the car since I got it home...
Problem #1 I am in the process of replacing the Rear Drums cause it needed nwe wheel bearings...so while I am at it I am replacing shocks, shoes on it....and a spindle cause one of the bearings broke and pretty much welded itself to the spindle...anyway the car came with a new parking brake cable cause the old cables snapped on both sides...it is just like the one I am posting a pic of below...am I missing something to go with this? It doesn't have the springs that go on the end that goes into the drum...I am wanting to put this on while I have it all apart and was trying to figure it out...
Problem #2 , the rear door handle wilol open from the inside only and not the outside...any direction on the way to go about fixing this would greatly help...
Problem #3 , the light on the dash says check fuel cap, should I just replace fuel cap or is there any other known problems that I need to know about this...Also the light showing the doors open is on but I made sure all doors were shut tight...
Problem #4 , cruise doesn't work...I replaced third brake light bulbs...now I am getting ready to check sensor on brake pedal...I honestly have not looked at it yet but is there a sensor on the clutch also that it goes against when clutch isnt pushed down, like the brake pedal...one that I need to check also...if so what is the proper name of it? So I can get a new one if that's what it is...
Problem #5 drivers side door won't lock...the actual door lock you can look at to see if the door is locked or not is not moving...that actual piece is broke does that actually keep the entire lock from locking?
This is just a few things I have found and there are more but I am going to start with these first. ..sorry if some of the questions sound stupid...I am completely new to a Ford Focus...I think I ended up with a project car without knowing it when I bought it but it's my own fault...
Thanks for any and all help on some of these problems...
