All,
I am very confused on what the issue could be. My car is over heating when i rev the engine or take it for a spin.
I can let the engine idle for an hour and the temp is normal. if i rev the engine for 10 minutes (around 2500rpm) it climbs up to red.
It has 130k miles on it.
I have replaced all hoses. I have flushed the system entirely twice, i have taken the radiator out and had it inspected (no blockages or gunk inside and has good flow)
I flushed out the heater core. It has good flow.
I replaced the thermostat (tested it in boiling water to make sure it works, my fans are kicking on (also replaced the resistor just in case)
The water pump seems good because it is cycling the coolant around the engine and there is pressure in the system.
No leaks. Not losing coolant anywhere.
The heat is up around 90*F coming out of the vents.
New Coolant reservoir cap.
I have followed the instructions in the Haynes repair manual on replacing coolant.. I feared i might have an air bubble, so i filled all the hoses up, engine block, and radiator, on the last time i drained the system, trying to eliminate any air pockets. I have left the cap off the coolant tank for up to 2 hours. Engine idles fine, i had a few bubbles to start, but by the end no bubbles.
I put the cap on, the system starts circulating... i can see the coolant in the tank go up and down like it is supposed to. All hoses are hot..all of them have pressure in it.
But as soon as i start reving the engine, the temp rises.. goes to red. i let off the engine.. it comes back down after a minute or 2. Both fans are kicking on. First the at idle fan and then the high speed fan eventually kicks on.
I have no coolant in the oil or in the piston area (spark plugs just got replaced and look brand new still.)
Im looking for help! I have used your forums for years (as i have had 5 ford focus cars.. This one has be baffled.
I dont think it is the head gasket nor do i think it is the water pump. I think i am missing something simple.. Help!
