I am in the midst of rebuilding an '03 ZETEC engine for my '01 4WD 5Spd Mazda Tribute. The original ZETEC is a bit tired and starting to consume oil. I picked up a low KM '03 for $200 and started this build.
Intake, Engine and Exhaust;
Custom 2.5" intake with 6" velocity stack and K&N Filter
'03 GSXR-1000 Throttles (46mm) w/GSXR Air box
Stg 2 Comp Cams / 06/12/14 Update: Now Stg 3 Comp Cams
Ported and polished '03 head
Intake
Exhaust
+1mm Oversized intake and exhaust valves
86mm Bore w/11:1 compression on stock rods,
put together at a local shop in Sussex.
4 - 1 long tube header with full 2.5" Magnaflow exhaust w/cat delete
Fuel, Ignition & EMS
255lph Fuel pump upgrade w/Mechanical returnless pump & housing
'08 Honda Accord COP ignition setup
MegaSquirt III engine management system
Also running a dual stage fuel injection system
250cc Primary injectors in stock location
240cc Secondary injectors located in throttle body throats (stock GSXR location)
Transmission
Fidanza LW flywheel w/Centerforce dual friction clutch kit
How she sits right now....
Just waiting for a few small parts and time off work to drop her into place!
More to come!
Intake
Exhaust
Transmission
More to come!
