Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - LED Headlights - Dipped Beam Bulb Fault
Old 05-19-2016, 03:02 AM   #25
rebelx
Fan#: 120081
What I Drive: 2014 SGM SE w/Sport Package
Points 5,346, Level 46
Points: 5,346, Level: 46 Points: 5,346, Level: 46 Points: 5,346, Level: 46
Level Up 98% Completed
FF Reputation: 2 rebelx Good Standing Member
Originally Posted by ELCouz View Post
But resistor are not needed if you use foCCCus to program the BCM to ignore the load on the headlamp wire.
I don't want to use foCCCus on my car. Would not having resistors w/HIDs create an overload load less than having resistors w/HIDs?
Essentially, if the car is still supplying X watts necessary to drive halogens to the HIDs, where does the excess go? Burn off as heat?
Isn't the point (from what I understood in limited conversation from some other folks) of resistors (besides canceling the error code) to safely handle the additional load that the HID system does not need but the car supplies regardless?
rebelx is offline
