Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - LED Headlights - Dipped Beam Bulb Fault
Old 05-18-2016, 07:49 PM   #24
ELCouz
Focus Preacher
ELCouz's Avatar
Fan#: 157898
What I Drive: '12 F. SE HB Candy Blue 5spd
Points 7,453, Level 57
Points: 7,453, Level: 57 Points: 7,453, Level: 57 Points: 7,453, Level: 57
Level Up 52% Completed
Forum Activity 5%
FF Reputation: 17 ELCouz Great Standing Member
Originally Posted by rebelx View Post
Wouldn't the car/harness be pushing 110w regardless if you have resistors or not?
I'm at the point where I haven't completely determined whether I need them or not.
Resistor are needed because the load of HID ballast are inductive and halogen bulb are resistive type of load... the BCM will "not see" the ballast load thus throwing a bulb out error thinking the bulb are burned.
But resistor are not needed if you use foCCCus to program the BCM to ignore the load on the headlamp wire.
ELCouz is offline
