Hey everyone I am about to run my SVTF on Sat at the track. I have a Procharger with the 8psi pulley (tuned by Hypnotic), ORP, FC TB, VF rear mount, Steeda STS, with 42lb injectors and motorcraft copper spark plugs. What does everyone think I will run? Later in the day I will be going to the dyno what does everyone think i will put down there?
Hmmm tough to say really... What kind of tires do you have, and have you ran the strip before? I dont know what kind of HP you are putting down but I think 12's is a little difficult for sub 300 hp? I have no clue what the procharger @ 8psi does to the svt though so i dunno.
I would say low 13's though as my guess (slightly uneducated without more info but thats what it is! )
I would probably warm them up then...generally I dont but if you plan on getting new tires relatively soon then just smoke them down a bit to get them warmed up (try turning the wheel to get the left tire to warm up to so your not peg-legging as bad at the start)
I am gonna prob run mine sat. nite...as long as my new rim comes by friday...... [thumb]...i'll post up the dyno as well....(gonna do a dyno/track day)
Based on the boosted Foci in my group here in AZ, I'd say that you'll probably be doing really well to get in the 13's. Don't want to bum you out, but the SVT (Getrag) is not an especially easy car to launch, and with stock conti's it'll be even harder to put to the ground even if you can hit the launch. My friend with a 250hp focus has run consistent mid-13's with drag radials. He has an MTX-75 which is a bit better for drags IMO. You should be mid to high 200's on HP though man which is super sweet. Me too later this year I hope.
I noticed you said you had the 8psi pulley on- what does the procharger kit come with usually? 8psi seems relatively low so just trying to figure out if thats what it came with or if it came with a lower 5-6psi pulley.
How much was your kit? I wouldnt mind putting a blower on eventually but cost is an issue for me.
well the powerworks makes about 210hp and 200tq and does about a 14 sec quarter on a svt. Toms full kit can do a 13 flat but produces around 280hp with about matching tq so i am going to say you will do a 14.0-13.7.
Related Threads
Focus Fanatics Forum
5.8M posts
189.4K members
Since 2003
