Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - gravel road cornering
Old 09-27-2015, 02:11 PM   #5
sailor
Old Phart
sailor's Avatar
Fan#: 57268
What I Drive: 2013 Black 5-spd SE Hatch
Points 33,746, Level 100
Points: 33,746, Level: 100 Points: 33,746, Level: 100 Points: 33,746, Level: 100
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 135 sailor Excellent Standing Member sailor Excellent Standing Member
Originally Posted by thenorm View Post
one of the biggest things for cornering speed on loose roads (gravel, snow, etc) will be tires. without knowing your tires, i couldn't recommend crazy speeds.
Sailor is right though, the signs are meant for all vehicles, RV,s trucks, etc, so cars can generally take them a bit faster.
1 piece of advice, don't drive faster than you can see. Don't cut blind corners, and don't commit too hard to a corner if you cant see the exit, all it would take is 1 decreasing radius at too high speed and you will quickly run out of road and head down a ditch (or worse).
Some great hints from thenorm & JoeyWhat.
"Slow in & Fast Out" is good for any unknown road, particularly gravel when the surface is constantly changing.
Dive in slower then you think you could, then as you see/feel conditions and the corner exit you can speed it up as you complete the turn & exit it.
"Rubber Side Down"
S.R. #275
Focus Takeover #003 / Tarbo Fan #003
sailor is offline
