Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Does your vent selector stick? Have you broken the cables? Read on,
Old 06-15-2013, 04:22 PM   #13
roberted5
Fan#: 115674
What I Drive: 2006,Black,LS
Points 434, Level 8
Points: 434, Level: 8 Points: 434, Level: 8 Points: 434, Level: 8
Level Up 68% Completed
FF Reputation: 1 roberted5 Good Standing Member
Originally Posted by fozziebear View Post
My 07 has a problem with sticking too.What I found is not in the cables or blower housing but the bled door it self.The rubber seal Ford uses gets sticky over time and doesn't release from the housing where it makes contact.If the center vent and duct is removed you can just get your hand to the top of the blend door and you'll feel it stick.As a short term fix spray some silicone spray on the blend door and work it limit to limit several times.This will last several months then it will need to be done again.
I tried removing the fan and blowing out the debris after replacing the cable,but it still sticks.In time if not fixed the cable will stretch and break again.
I'll have to try what your saying.
To remove the center vent,I'm going to lube the blend door,is it needed to remove the radio?Is there any screws that need to come off?
roberted5 is offline
