Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Driver door not opening from outside
Old 07-25-2008, 03:01 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,945, Level 94
Points: 23,945, Level: 94 Points: 23,945, Level: 94 Points: 23,945, Level: 94
Level Up 60% Completed
Forum Activity 9%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
It's the door handle itself. Do a search and you will find about 10,000 others who have had the same issue. Replace the door handle and problem solved, or you can pull the door apart (which you will have to do anyways) and clean it. Though that is just a temp fix, it will return at the most inopportune time.
If you need to get in, just push in on the door a little and pull the handle at the same time. Should open right up then. That's what I do because I am too lazy to fix mine.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
