Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replacing Sony speakers
Old 05-23-2019, 10:17 AM   #3
firebirdude
Fan#: 48824
What I Drive: 2013 Ruby Red SE Hatchback
Points 22,640, Level 93
Points: 22,640, Level: 93 Points: 22,640, Level: 93 Points: 22,640, Level: 93
Level Up 29% Completed
FF Reputation: 12 firebirdude Great Standing Member
Install them. One of a few things will happen, none are bad.
  • The factory had no crossover in-line, so you just saved your tweeter's life.
  • The factory crossover is set higher than the crossover you have, in which case your crossover is already in the crossed-over band and will make no audible change.
  • The factory crossover is set lower than the crossover you have, in which case you needed your crossover to protect your tweeters to Infinity's spec.
  • The factory crossover and your crossover are set at the same frequency, in which case the rolloff will increase and roll-off those unwanted frequencies at a steeper curve.
firebirdude is offline
