Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2014 ford focus no crank no start problems everywhere
Old 05-16-2019, 01:39 AM   #7
MechanicMom
Fan#: 412547
Points 1, Level 1
Points: 1, Level: 1 Points: 1, Level: 1 Points: 1, Level: 1
FF Reputation: 1 MechanicMom Good Standing Member
Yes you can hear the fuel pump. The selector says its in park amd it is in park that problem was solved when I fixed the ground. When i had the issue with the rock and the radiatkr the active grill shutter waa damaged and i coukd not afford a new one so i just removed it. Along with the 5amp fuse that went to it. I was reaging somewhere that if you run out of oil or have the wrong viscosity of oil in there that it can cause those codes. I really dont want to have to take it to Ford and i don't want to have to get it reprogrammed.
MechanicMom is offline
