Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Idle and Stalling issues
Old 05-15-2019, 07:51 AM   #4
nayman898
nayman898's Avatar
Fan#: 349641
What I Drive: 2004 Red SVT, 2007 Gray ST
Points 720, Level 14
Points: 720, Level: 14 Points: 720, Level: 14 Points: 720, Level: 14
Level Up 20% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 1 nayman898 Good Standing Member
Originally Posted by SVTailights View Post
Probs vaccum leak smoke test if you can, check intake hose clamps
So I cleaned the IAC, that helped with idling when I come to a stop. The symptoms now seems to only happen when I start the car. The car turns on and idles high for a moment, then slowly starts to go back down. If at any point within the first 2-5 minutes of the car running I touch the gas pedal, the engine bogs and goes Down in revs, unless I really kick the pedal, in which case it reluctantly revs, and then makes a weird noise from the Intake manifold. It seems to happen most often around 2-3k rpm, it sounds like a plastic vibrating against plastic, I checked all around the exterior of the intake manifold and didn't see anything could vibrate against it, so I am assuming that it is inside the manifold.
Furthermore, I recently replaced my tensioner, and I am worried that its a little tight, but I am not sure how tight it should be, and what the implications of a belt being to tight would be. I have an Underdrive pulley on the way and I was hoping that would help ease my worries on the belts and what not.
nayman898 is offline
