Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Break pad and rotor recommendations for Mk3 SE?
Old 05-06-2019, 06:52 AM   #22
soviet911
Fan#: 383881
What I Drive: Ford Focus 2014 SE
Points 204, Level 4
Points: 204, Level: 4 Points: 204, Level: 4 Points: 204, Level: 4
Level Up 8% Completed
Level up: 8% Level up: 8% Level up: 8%
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 1 soviet911 Good Standing Member
Thanks all. did the job after swapping out those junk lug nuts. The new pads and rotors are quiet so far, and have good breaking power even without bedding so would recommend the akeboro proact pads and Wagner e-coated rotors (I also only washed these with soap and water before install).
The install was pretty simple once the lugnuts came off. No suprises anywhere, the only thing is make sure to have a breaker bar to remove the bolts(18mm) holding on the caliper braket to get the rotors off, the bolts are thread locked on so i had to use a 25 in breaker bar to get them off. Everything else was simple, took about 40-50 min a side taking my time in a parking lot.
soviet911 is offline
