Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2005 2.0 Exhaust manifold / cat removal.
Old 05-04-2019, 07:35 PM   #14
Fordfool
Fan#: 412491
Points 3, Level 1
Points: 3, Level: 1 Points: 3, Level: 1 Points: 3, Level: 1
Level Up 5% Completed
Level up: 5% Level up: 5% Level up: 5%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 1 Fordfool Good Standing Member
Exhaust Manifold Stuck
We have a 2005 ZX4 SES 2.0 Duratec with a broken flex pipe. It has a mani-cat with the exhaust manifold, catalytic converter, and flex all 1 piece. I have everything disconnect and the assembly is loose but I can't figure out how to pull it up and out from under the hood. Doesn't seem like there is enough room/clearance. I have not removed AC lines or heater hoses. Do I need to remove motor mounts to loose/move the motor to make room to pull this up and out? What am I missing?
ANSWER: I set out this morning and removed both driver and passenger side upper motor mounts. That gave me just enough movement. I let the manifold lower back towards the firewall and then I was able to pull the manifold heat shield off. Once that was out of the way the mani-cat lifted right out.
Fordfool is offline
