Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - wiper blade hitting windshield seal
Old 04-25-2019, 12:01 AM   #5
amc49
Fan#: 96610
Points 9,383, Level 65
Points: 9,383, Level: 65 Points: 9,383, Level: 65 Points: 9,383, Level: 65
Level Up 11% Completed
Forum Activity 100%
FF Reputation: 62 amc49 Excellent Standing Member
I have never seen a wiper setup that could not have the wiper arms re-indexed to a more correct timing by simply removing them and putting them in a slightly different place to retime the stop or extreme travel position. Per post #3. The arms generally fit on splines and makes it easy to move them a little bit.
On at least the earlier ones you simply remove the nut under the cover and pop the wiper arm loose and move it slightly and bolt it back down.
Fix the driver first, then fixing the car becomes so much easier..........
amc49 is offline
