Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Testing 8S4Z-9P471-A Tumbler Rotary Position Sensor on 2.0L
Old 04-20-2019, 01:51 PM   #19
[email protected]
Fan#: 338626
What I Drive: 2010 Red Focus SEL
Points 133, Level 2
Points: 133, Level: 2 Points: 133, Level: 2 Points: 133, Level: 2
Level Up 66% Completed
Forum Activity 72%
Activity: 72% Activity: 72% Activity: 72%
FF Reputation: 1 mscotese@aol.com Good Standing Member
Marde,
Again, many thanks for the help!
I did the following key on, flaps open, voltage tests and IMRC Module pin 2 measured 0.7v on every one. The voltages measured the same with two different IMRC Modules.
MAP plugged in and IMRC plugged in and unplugged
MAP unplugged and IMRC plugged in and unplugged
I did the following key on, flaps open, voltage tests and MAP Sensor pin 2 measured 0.7v on every one.
IMRC Module plugged in and MAP Sensor plugged in and unplugged
IMRC Module unplugged and MAP Sensor plugged in and unplugged
In addition I measured a change in voltage at the IMRC Module pin 2 from 0.7v to 0.1v when manually moving the flaps from open to closed. This was also with key on and both MAP and IMRC Modules plugged in.
What now? New PCM?
Thanks, Mike
mscotese@aol.com is offline
