Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Testing 8S4Z-9P471-A Tumbler Rotary Position Sensor on 2.0L
Old 04-19-2019, 11:01 PM   #18
Marde
Marde's Avatar
Fan#: 115991
What I Drive: 2004 ZTW PZEV 2.3 ATX
Points 15,193, Level 79
Points: 15,193, Level: 79 Points: 15,193, Level: 79 Points: 15,193, Level: 79
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
FF Reputation: 51 Marde Excellent Standing Member
I had mistakes-typos on pin-numbers info above, but is now corrected.
Place the meter black test lead at either of (any one of) these locations:
Module pin-3 (is a green/white wire)
MAP Sensor pin-4 (is a green/white wire)
Cylinder Head Temp (CHT) Sensor pin-2 (is a green/white wire)
Sorry about my ground-reference brain-fart mistake. The "free" help info found on the web, posted by Marde, should always be suspect bad info or complete BS.
Gd Luck
Always check your fluid levels, -then check your car.
Marde is online now
