Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Testing 8S4Z-9P471-A Tumbler Rotary Position Sensor on 2.0L
Old 04-18-2019, 06:46 PM   #12
[email protected]
Fan#: 338626
What I Drive: 2010 Red Focus SEL
Points 133, Level 2
Points: 133, Level: 2 Points: 133, Level: 2 Points: 133, Level: 2
Level Up 66% Completed
Forum Activity 72%
Activity: 72% Activity: 72% Activity: 72%
FF Reputation: 1 mscotese@aol.com Good Standing Member
Thanks for the additional info. I am not sure what you re referring to when you say "the module"
I did have a diagnostics code for a MAP sensor a couple of weeks ago but when I replaced the MAP sensor it went away.
I do have a meter and know how to use it but am not sure which terminal to check voltage across and what the readings should be and under what conditions.
Once again what is "the module" you refer to please??
Thanks, Mike
mscotese@aol.com is offline
