Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 05 ZX4 SES Duratec Issues
Old 04-08-2019, 07:30 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 33,055, Level 100
Points: 33,055, Level: 100 Points: 33,055, Level: 100 Points: 33,055, Level: 100
Forum Activity 100%
FF Reputation: 87 felixthecat Excellent Standing Member
It could very well be the egr valve, unplug it(driver side) & see if that makes a difference & I'd also open the t/b throat & spray some carb/throttle body cleaner down the throat as well as the inside edges where the blade operates. I'd swap out the fuel filter & make sure you get the clips w/ it.....Jack up the rear of the car of course use jack stands & you'll see the filter, you'll need to get the special filter clip wrench & use the oil drain pan.
felixthecat is offline
