Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Does anyone have a trunk wiring diagram?
Old 03-26-2019, 09:09 AM   #12
SupraGuy
SupraGuy's Avatar
Fan#: 410021
What I Drive: 2012 White Focus 5 door Titanium
Points 344, Level 6
Points: 344, Level: 6 Points: 344, Level: 6 Points: 344, Level: 6
Level Up 88% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 1 SupraGuy Good Standing Member
Originally Posted by Cducasse View Post
This just occurred in my car. 2012 Ford Focus. I stripped the wires back a bit to leave rooom to reconnect them but I need to add wire to make it work. I donít have any wire other than some speaker wire which I believe is two conductor. Can I use that?
I would probably get some more appropriate wire, but in general, yes, you should be able to splice in some other wire. Most speaker wire can be split by pulling the two conductors apart. make sure that the wire is of at least a similar size, and be sure to insulate the splice well.
It's not a terribly difficult job, but there are things that can go wrong.
SupraGuy is offline
