Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Can you change the timing tensioner without redoing the timing belt?
Old 03-21-2019, 10:19 AM   #1
Svtsc
Fan#: 388994
What I Drive: 04 focus svt silver
Points 883, Level 15
Points: 883, Level: 15 Points: 883, Level: 15 Points: 883, Level: 15
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 1 Svtsc Good Standing Member
Hello again. So recently 300miles ago I changed timing belt all associated pulleys and water pump. I used the gates kit everything is fine but i keep stumbling on threads here, Facebook ect saying the gates tensioner is not rated at the right lbs of pressure (I've also seen a similar amount of threads saying the gates kit is fine ect). So I am wondering can I replace just the tensioner with an oem Ford one without redoing the entire process!? I saw a thread asking a similar question however that devolved into a pissing match over who knows more lol. Thank u all for your time. Th
I also forgot to mention that the gates tensioner (everything is timed correctly btw no cel) bar has moved. Thx again
Svtsc is offline
