Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - P1633 code plus electrical smoke
Old 03-19-2019, 12:12 PM   #10
pizzaboy192
Fan#: 410303
Points 171, Level 3
Points: 171, Level: 3 Points: 171, Level: 3 Points: 171, Level: 3
Level Up 43% Completed
Forum Activity 3%
FF Reputation: 1 pizzaboy192 Good Standing Member
Originally Posted by rusty_apache View Post
Thanks for the information.
So smashing it and driving around without it is probably just going to cause more electrical problems down the road. Good to know.
Is there any way of locating the replacement MOV1? Iím sure Ford would prefer that I buy a brand new cluster instead of a 59 cent component.
If you need to, just get a low mileage cluster from a pick n pull, (anything lower than your current mileage) and use Forscan to change the mileage once you've swapped the cluster.
I'm not sure if that part has any documented specifications to swap just the piece, but my local pNp sells clusters flat rate for $30
Edit: you could also grab any cluster and just swap the damaged part too and keep using your existing cluster. Probably could get one for cheap off the buy/sell/trade from someone who has a high mileage cluster or one with damaged servos or something.
Sent from my Moto G (5S) Plus using FF Mobile
pizzaboy192 is offline
