Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Is My Brand New Orielly's Slave Defective?
Old 02-27-2019, 06:10 PM   #22
cheap sleeper
cheap sleeper's Avatar
Fan#: 59848
What I Drive: 2001 black zx3
Points 3,318, Level 35
Points: 3,318, Level: 35 Points: 3,318, Level: 35 Points: 3,318, Level: 35
Level Up 79% Completed
Level up: 79% Level up: 79% Level up: 79%
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
FF Reputation: 5 cheap sleeper Good Standing Member
So, UPDATE AGAIN. Still no clutch!!
I have officially swapped 2 new slaves a new MC, I just replaced the disc that had sheared the pads off and I replaced the pressure plate too.
Everything has been replaced at least once now.
The pressure line is not swelling or leaking when clutch is pressed.
There are zero leaks anywhere.
I easily get all of the bubbles out in minutes and have a firm pedal, same as before.
Still no clutch.
Only thing I haven't replaced is the line (which feels good the wbole run and doesn't leak), and the flywheel.
I did have it turned, but, where I take all my focus FWs, they always do a perfect job and check the specs afterward to make sure all is well.
I am at the point of blaming it though.
I am sick of pulling this trans and putting it back in only to be laughed at.
My SVT and daily ZX3 bleed in 5 minutes or less and work perfect everytime.
I have had the trans on this turd in and out 3 times now with the same result.
Great pedal, no clutch.
No one has ever had this ridiculous problem?
Sent from my SAMSUNG-SGH-I527 using FF Mobile
cheap sleeper is offline
