Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - clutch master cylinder main line from hell/line measurements?
Old 02-03-2019, 10:43 AM   #5
ant07
Fan#: 390402
What I Drive: 2007 ZX4
Points 86, Level 1
Points: 86, Level: 1 Points: 86, Level: 1 Points: 86, Level: 1
Level Up 72% Completed
FF Reputation: 1 ant07 Good Standing Member
Thanks for your replies.
The fuse box, battery tray, and transmission mounts are out. I have removed the C clips. I even thought there might be two somehow so I blindly felt the underside with a pick to be sure there are no other retainers.
I have tried to pull as straight as possible initially, but I did just go nuts on it after it would not budge. The line holder came out first without me having to intentionally remove it. The CMC was bolted on still, but now there is play and clicking sounds if I push the line in and out as if I have stripped something. I am not sure. I will keep trying.
Anyone think there is a way to remove from the inside?
ant07 is offline
