Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Traction Control Light Solid all the time
Old 12-18-2018, 03:01 PM   #6
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
What I Drive: 2007 ZX3 2013 ST3
Points 12,713, Level 73
Points: 12,713, Level: 73 Points: 12,713, Level: 73 Points: 12,713, Level: 73
Level Up 66% Completed
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
FF Reputation: 42 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Originally Posted by felixthecat View Post
Brake light on = possible low on brake fluid....abs light= tone ring, wiring or a sensor...tcs hooked to the abs.
The hand brake has a switched tied to the brake light as well iirc.
Did you change any of the braking components? Need to make sure any replacement parts were for an ABS car or you swapped over those tone rings. What happens when you panic stop in a low traction situation? Find an empty road or parking lot. If the brakes just lock up, that will tell you ABS is not working at all
rambleon84 is offline
