Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Transmission cooler return line removal HELP
Old 11-17-2018, 06:13 PM   #2
amc49
Fan#: 96610
Points 9,508, Level 65
Points: 9,508, Level: 65 Points: 9,508, Level: 65 Points: 9,508, Level: 65
Level Up 53% Completed
Forum Activity 100%
FF Reputation: 62 amc49 Excellent Standing Member
Not piccing it did not help your cause. Ford uses only like 40 different types of snap-on retainers. Some like the duckbill type require a separate small tool to do it. Tool inserts in to open the clamping spring up to let loose the other side. Tool is cheap and you will destroy that connector before it comes loose not using it.
Do a google search using the words 'transmission line disconnection tool' and get swamped.
Fix the driver first, then fixing the car becomes so much easier..........
amc49 is online now
