Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Snorkel Delete
Thread: Snorkel Delete
Old 10-13-2018, 02:06 AM   #2218
novus
novus's Avatar
Fan#: 107022
What I Drive: '12 Tuxedo Black Focus SEL
Points 2,020, Level 27
Points: 2,020, Level: 27 Points: 2,020, Level: 27 Points: 2,020, Level: 27
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 6 novus Good Standing Member
Originally Posted by sftwengnr View Post
I was wondering if these mods will work on a 2014 5 sp SE?
I have the RS airbox on my focus as well.
I was wondering what will be the impact on the throttle response for a car in the Denver area which is at 5280 ft above see level?
thanks
bob
Originally Posted by RonMaiden View Post
Too much flow through the engine at this altitude might actually slow you down a bit up here and push torque higher up in the rpms and we need all the torque we can get the 2900lbs moving if you really want to see a real world diff.
IMO save your money or buy a turbo ST if you want to defeat the altitude a bit.
I'm at 5,000ft-6,000ft ASL and I don't have too many issues with low end torque. Just ensure you're using 91 instead of 85.
Originally Posted by anshulrouthu View Post
I tried the setup you are describing on my 2013 focus SE 5 spd manual, and did not like it.
I had first deleted the snorkel and dropin AEM filter with stock airbox, observed noticeable improvement in throttle response and low end pickup.
After a few hundred miles I added full rs airbox setup, increased the sound of intake (only above 3-4k rpm) and also observed drone at about 2~2.5K rpm while cruising in city traffic. Did not improve the performance, slightly reduced it, ambient temperature was around 100F and IAT's were 120+ around that time, I was heat soaking, so I went back to just snorkel delete + dropin AEM with stock airbox.
I am planning on 63mm throttle body upgrade and RAM air snorkel (3D printed)
Anshul
63mm, stock airbox, snorkel, and airbox resonator delete works perfect.
Hatch Nation #118
novus is offline
