Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus se crank but no start
Old 07-27-2018, 03:27 AM   #21
Keefvscott
Fan#: 403379
Points 74, Level 1
Points: 74, Level: 1 Points: 74, Level: 1 Points: 74, Level: 1
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 3%
FF Reputation: 1 Keefvscott Good Standing Member
I did not inspect the filter at all. I used a stick to prop open the tank hole to dump the gas out and it got stuck inside the tank so I took the fuel pump out to do that, but I didnt think about checking the filter. Everyone I call says its lifetime and doesnt require maintaince. Think if battery is too low then it wouldnt start? The light has been on even after I charge it, it stays on. And i also need an oil change. The terminals sucked and there is a chip on the ground connecting to the battery but it is basically all the way corroded. Think that could be it maybe?
Keefvscott is offline
