Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus se crank but no start
Old 07-24-2018, 11:09 AM   #13
Keefvscott
Fan#: 403379
Points 74, Level 1
Points: 74, Level: 1 Points: 74, Level: 1 Points: 74, Level: 1
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 3%
FF Reputation: 1 Keefvscott Good Standing Member
Oh ok I see what you mean. Now the fuel rail is hard to find. The line coming from the pump in the tank goes directly to the high pressure fuel pump then directly to the engine. The fuel barely leaks out going into the HPFP, so today im going unhook it at both ends and blast air through it to see if there is any blockage. Then im gonna run the pump before i reconnect it to see how much fuel comes out. The pump seems good but im not sure. I replaced the positive battery line because it was extremely corroded all through the wire. Too bad i brought from dealer as is.
Keefvscott is offline
