Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dealer Almost Voided My Warranty!
Old 07-23-2018, 02:40 PM   #20
BillytheBBQMaster
BillytheBBQMaster's Avatar
Fan#: 401890
What I Drive: 2018 Focus
Points 18, Level 1
Points: 18, Level: 1 Points: 18, Level: 1 Points: 18, Level: 1
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 1 BillytheBBQMaster Good Standing Member
Originally Posted by sykozis View Post
Whether a lubricant meets the manufacturer's lubricant specification or not, the warranty can NOT legally be voided as long as the proper oil weight is used.
That's only partially true. It's not the weight, it's the "oil spec". Each vehicle has it's own oil spec. BMW has LL-01 while some Ford vehicles may require WSS-M2C937A. Even if both oils were the same viscosity, you could not interchange them. A warranty can only be voided if the WRONG oil spec was used. The Magnuson-Moss Warranty Act makes it so that you can legally use any oil you wish as long as it meets the manufacturer's specs. If the manufacturer "requires" you to use a certain brand oil, then by federal law they are required to provide that oil to you free of charge, per Magnuson-Moss Warranty Act.
BillytheBBQMaster is offline
