Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus se crank but no start
Old 07-23-2018, 10:15 AM   #10
Keefvscott
Fan#: 403379
Points 74, Level 1
Points: 74, Level: 1 Points: 74, Level: 1 Points: 74, Level: 1
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 3%
FF Reputation: 1 Keefvscott Good Standing Member
Originally Posted by zacautomotive View Post
His Focus has direct injection it's more complicated. What was this bad fuel situation? I'm sorry for your job loss sounds like a crappy employer that doesn't understand. If you worked where I work somebody would have picked you up and took you.
Sent from my LG-LS997 using FF Mobile
Ima make this short. I had bad gas so i tried to burn some out but it didnt go well. So I dropped the tank and drained it. I put it back in and now someone is tell me that i have to release the air in the line before it hits the high pressure pump under the hood. Doing so by turning key to run the fuel pump thats integrated with the tank. I was told that when i have a significant amount of fuel to put the line back in the high pressure fuel pump and unhook the other end of it so fuel runs through it. (Method Ill be trying today). I know it was bad fuel because it was green and brown.
Keefvscott is offline
