Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - NASA Spec Focus Upgrade
Old 06-24-2018, 06:38 PM   #102
Pappy
Fan#: 347898
Points 278, Level 5
Points: 278, Level: 5 Points: 278, Level: 5 Points: 278, Level: 5
Level Up 56% Completed
FF Reputation: 1 Pappy Good Standing Member
Flare Progress
Here are a few status photos of the fender flare project. The forth flare (left rear) buck is still on the car. When the bucks are finish sanded and painted, I will pull permanent molds off of them and then pull the finished products from the molds. There will still be work to do to build the mounting flanges, separate the extensions that run down the front bumper from the fender portion of the flare, and build in the rear door openings. When that is done I will cut the metal that is keeping the wider tires from full compression travel and attach the finished (painted) flares. Still a good bit of work to do - its a slow, time intensive process.
Pappy
Name:  Focus Flares 1.jpg
Name:  Focus Flares 2.jpg
Name:  Focus Flares 3.jpg
Name:  Focus Flares 4.jpg
Pappy is offline
