Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - The 2019 Season is Here!
Old 03-11-2018, 11:13 PM   #8
sailor
Old Phart
sailor's Avatar
Fan#: 57268
What I Drive: 2013 Black 5-spd SE Hatch
Points 33,746, Level 100
Points: 33,746, Level: 100 Points: 33,746, Level: 100 Points: 33,746, Level: 100
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 135 sailor Excellent Standing Member sailor Excellent Standing Member
You set a high goal, G/L with the Season!
And yep, not in a momentum car anymore - more power & braking where needed - and LESS than you hope to be able to use.
IIRC, last year you tended to push Slaloms faster while going through, eventually getting behind the line & spinning out for the bad runs.
FWIW - in Ski racing you want to be finishing the turn as you go by the back side of the pole (cone), otherwise you get behind and can't turn sharp enough for the next one. Similar early start should help, gives you more time for a better line than being forced to turn sharp AT the cone.
"Rubber Side Down"
S.R. #275
Focus Takeover #003 / Tarbo Fan #003
sailor is offline
