Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - NASA Spec Focus Upgrade
Old 02-17-2018, 05:11 PM   #84
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 01 ZX3, 04 ZTW, 12 SE Sport, 17 ST3
Points 2,035, Level 27
Points: 2,035, Level: 27 Points: 2,035, Level: 27 Points: 2,035, Level: 27
Level Up 24% Completed
FF Reputation: 6 teamDFL Good Standing Member
Originally Posted by Viper 00 View Post
Got most of the rear suspension in. The MKIII ST trailing arms and all of the links went in without a hitch. I used Massive's upper camber link and toe link. With only minor modification the MKIII FsWerks fit the MKI cradle. Karl at Massive is building me a stronger pair of sway bar links. I used slugs on the lower control arm and the inboard end of the toe link so I could adjust the roll center. I did have to raise the shock upper mount to make sure the shock would not bottom with full compression.
Pappy
Attachment 244553
Attachment 244561
Attachment 244569
What is the advantage of the Mk3 trailing arm?
Rich
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
