Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Clearing MyKey without Admin Key
Old 07-30-2017, 04:58 AM   #65
novus
novus's Avatar
Fan#: 107022
What I Drive: '12 Tuxedo Black Focus SEL
Points 2,041, Level 27
Points: 2,041, Level: 27 Points: 2,041, Level: 27 Points: 2,041, Level: 27
Level Up 28% Completed
Level up: 28% Level up: 28% Level up: 28%
FF Reputation: 6 novus Good Standing Member
Originally Posted by volliefd View Post
Ok two questions should the elm be in hs or ms can? And key at acc level? I had it at the on level. I already planned to get new key from locksmith. Got a call into one that has a 4.8/5.0 rating.
Base pull from BCM had it set at 2. I changed it to 0 and loaded and it took, but I thought it was odd when I turned car back on it still said mykey on the screen. I thought it wouldn't say anything.
Ok now this dumb question came to mind, if I go get a new key made at a locksmith won't that be an admin key and I don't even have to do the focccus reprogram???
Set it to "0", and flash. Once that's done, get out of the car and lock it. Wait a min and get back in. The MyKey option should no longer be available when you turn the car back on and go through the menus. When you set the value back, MyKey will reappear but will have been disabled.
Let us know if you have any further issues.
Hatch Nation #118
novus is offline
