Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Battery change and BMS reset?
Old 06-12-2017, 07:00 AM   #22
Bud Bundy
Bud Bundy's Avatar
Fan#: 118640
What I Drive: 1.6 EcoBoost 150HP HB Titanium
Points 462, Level 9
Points: 462, Level: 9 Points: 462, Level: 9 Points: 462, Level: 9
Level Up 24% Completed
Forum Activity 3%
FF Reputation: 2 Bud Bundy Good Standing Member
Originally Posted by Garland15949 View Post
i was wrong. after more run time today it peaked at 14.5 volts 110 amps. i definately can see the smart charging working seems to charge more going down hills or when you lift off the gas pedal
This is correct and normal.
If you "going down hills or when you lift off the gas pedal" the charging voltage goes up to 15.0 Volts.
In lead-acid's batteries (no Smart Charge System), the charging voltage remains continuously at 14.4 volts.
Ford Focus Mk3 1.6 EcoBoost 150HP (07/2011) Panther black metallic.
Bud Bundy is offline
