Rear suspension . How to....get you in trouble...... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-28-2006, 10:46 PM   #1
mpcv2000
mpcv2000's Avatar
Fan#: 23629
What I Drive: 01 SE + 1989 RX7
FF Reputation: 19 mpcv2000 Great Standing Member
Unhappy Rear suspension . How to....get you in trouble......
What's up ?
Finally decided to lower my ride but I'm running in some inexpected problems and expenses.
The bolts of my rear arms ( hope not all of them ) are seized in the bushings so that mean I just destroyed 2 bushings trying to remove the bolts from the rear lower arms . The bolts are seized so badly in the inner metal bushings that it destroyed the rubber wrapped around it and since I was able to unscrew it with a 1/2" long pry-bar the "base" where the bolts goes thru spreaded apart ( see photos ) , I can fixe that but the 2 rear lower arm are screwed and I will need new one but now I have to find a way to cut the bolts without damaging stuff around it. So what I thought was gonna be a fun little projet just frozed my car in my garage for I don't know how long.
Anyone of you ran into seized bolts in the rear suspension ?
Here's the project car :
On this pic the car is ( left rear and right front ) to help you locate the parts on picture you are looking at .
This bolt is seised on the bushing , I can't heat it that much since the bushing will melt because they are rubber even if they are "shot" I need to remove the arm somehow without burning the car , I need to buy a small grinder with a wheel not too big to be able to squeeze it between the arm and the bushing to cut it.
With the rear of the car always on the left you can see how badly I spreaded the "base" where the bolt goes thru :
Here you see the bolt giving me trouble , I have the feeling they will be all like that .
The car is a 03 and haven't see snow or rain since May 2005 but did before so damaged is done .
I'm not a professionel mechanic and do it as a hobby but this issue is charlenging me pretty good.
This is again ( right rear ) the 2nd bolt I started to work on and I'm having the same problem, to go further I need to buy a tool to help me cut the bolts safely.
I'm open to any virtual input to help me take all this stuff apart , I'll be taking out the whole rear suspension to grease if possible of replace all seized parts I have to.
Martin !
mpcv2000 is offline
Old 09-28-2006, 11:14 PM   #2
lildisco
RespectMyAuthoritah!
lildisco's Avatar
Fan#: 5761
What I Drive: 06 Mazda6i, 08 Mazda CX7 GT AWD
Points 30,555, Level 100
Points: 30,555, Level: 100 Points: 30,555, Level: 100 Points: 30,555, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 47 lildisco Great Standing Member
Buy-Sell-Trade Rating: (8)
My LCA Bolts were frozen too. I was actually able to take what i think are the rear chamber bolts out and basically swung the LCA's out towards the outside of the car. The second pic has a dash on the frame to where LCA meets the Frame. Hope that helps.......
"I flushed a bag of skittles down the toilet yesterday and watched a NASCAR race in 8 seconds flat."
06 Spring Into Focus Best Sedan/Wagon Winner
03 SE SVT Wannabe (sold) to help pay for my 08 Cooper Red Mazda CX7 AWD GT
lildisco is online now
Old 09-28-2006, 11:17 PM   #3
archie
Fan#: 9921
What I Drive: 2008 Lexus IS-F
FF Reputation: 1 archie Good Standing Member
are you just adding springs or are you doing shocks/struts as well.
archie is offline
Old 09-29-2006, 05:26 AM   #4
mpcv2000
mpcv2000's Avatar
Fan#: 23629
I'm not doing shocks or struts for now , I'm just lowering the car , if bolts weren't frozen it will have been a easy job but it's not the case.
lildisco , this is a good idea what you are suggesting me , I wish I would have think about it before but since the right rear bushing is destroyed I need to find a way to take it out.
Today I'll go shopping for a cutting tool....
Martin !
mpcv2000 is offline
Old 09-29-2006, 06:56 AM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,233, Level 100
Points: 138,233, Level: 100 Points: 138,233, Level: 100 Points: 138,233, Level: 100
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (11)
Why don't you just get a spring compressor and and compress the spring? Though I know your too far into it and will have to replace the bushings though it is now the perfect excuse to upgrade the bushing with some energy suspenison bushing. I may be wrong but I thinkyou might have enough room to get a spring compressor in there I do know there are different styles of spring compressors. I wish you all the luck in fixing it. Oh and great photos and documenting of the problem.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 09-29-2006, 07:35 AM   #6
bacarl
bacarl's Avatar
Fan#: 31588
What I Drive: 05 InfraRed ST-T
FF Reputation: 5 bacarl Good Standing Member
Impact wrench, baby. Those work exceptionally well at removing stubborn bolts. You'll need new bolts and bushings anyhow so go ahead and torque the hell out of the frozen ones. Looks like you have some oil or something on there already, but let some good quality pentrating oil sit on there for a good long time and then hit it with an impact. You'll need to borrow an air compressor too - hopefully a local shop or someone you know can loan you the equipment.
Oh and Sleepyboy, spring compressors suuuuck! Esp in a confined space like that, ugh! You're forced to use them for the front Macphersons but in the back, it takes about 2 minutes to lower the control arm out of the way and drop the spring out the bottom... ...unless your bolts are stuck
Best of luck mpcv
Brian
2005 InfraRed ST FS Stage 2 (Totaled)
2008 BlackMica Mazdaspeed3 GT
bacarl is offline
Old 09-29-2006, 08:45 AM   #7
Focusnewb
Focusnewb's Avatar
Fan#: 27975
What I Drive: 2001 Sangria Red 4dr SE
Points 1,817, Level 25
Points: 1,817, Level: 25 Points: 1,817, Level: 25 Points: 1,817, Level: 25
Level Up 17% Completed
FF Reputation: 11 Focusnewb Great Standing Member
Buy-Sell-Trade Rating: (4)
I had to cut all of the bolts off of my rear control arms. The pisser was that you cannot replace just the bushings, they are manufactured into the control arms so I ended up buying new rear control arms.
I suppose it's possible to rig something that would have worked instead but I needed it back together quick. The control arms were $60 each and the new bolt for the upper end of the control arm with new nut and washer were like $15 each.
Panties aren't the best thing in the world but they are next to it.
I would rather drive the slow car Rusty built than the slow car I built.
Do your own repairs, it's not rocket surgery !!
Focusnewb is offline
Old 09-29-2006, 08:59 AM   #8
Black&Tan
Black&Tan's Avatar
Fan#: 9971
What I Drive: '06 Liquid Grey SES hatch
Points 5,976, Level 50
Points: 5,976, Level: 50 Points: 5,976, Level: 50 Points: 5,976, Level: 50
Level Up 13% Completed
FF Reputation: 8 Black&Tan Good Standing Member
Buy-Sell-Trade Rating: (9)
This is a common problem with the focus rear suspension. It happened to me when I did my install.... although I got off easy and only had to replace one lower control arm. Ford should have made the bushings seperate so you wouldn't have to replace the whole arm.
HN #171
Black&Tan is offline
Old 09-29-2006, 10:36 PM   #9
mpcv2000
mpcv2000's Avatar
Fan#: 23629
Day 3....
Impact wrench won't do much since the bolts are frozen in the bushings .. Today I bought a grinder with a few cutting wheels and I cut everything and stopped by the Ford dealership to get new arms and bolts. I did try with a spring compressor tool but no luck and I don't want to have frozen bolts in my suspension anyway. I was suppose to take everything apart but I just want to put the pro-kit in and drive the car a bit more before putting her away for the winter , I'll have plenty of time to take everything apart and buy more new parts if I have too.
Here's my new arms and my grinder , this grinder cuts bolts like butter , I just had to be carefull not to destroy stuff around what I was working on .
First bolt down with tons of sparks all around me....
First one is down...finally
This is the rest of the bolt stuck in the arm...
Now the other side.....
One bolt down... one more to go...
That's it , it's out....
I have a very tiny garage but it's perfect for my need....
There's tons of smoke that came from cutting and grinding part of the evening....
I have also a PC and a wireless keybord , mouse and speakers loged on XM radio to have some nice tune while doing my hobby...
Tomorrow will be cleaning all rear suspension parts , toutch up paints and putting it back together before attacking the front end. I love doing that when you have the tool for it . I can't beleive all the weird bolt sizes Ford is using , I need to get a 18mm socket tomorrow, I have one but it's only 3/8 drive and 1/2" is better when you need to pry hard on them..
More to follow tomorrow evening...
Martin !
mpcv2000 is offline
Old 09-30-2006, 03:54 AM   #10
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Nice to see you got a good tool and are getting it done. Sorry to see it was such a pain, but just keep going. Are you sure you don't want to do the shocks and struts while you are here and get it over with??
Good work so far !!
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
