HOW-TO: Swap in Tilt Steering Column/Replace Clockspring. - Page 4 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 07-01-2011, 11:08 PM   #31
kris4christ2
kris4christ2's Avatar
Fan#: 59197
What I Drive: 2005 Silver ZX4
FF Reputation: 4 kris4christ2 Good Standing Member
Originally Posted by tjr28602 View Post
I also have the B1932 diag code on my 2005 se4. It looks as if we have the same problem. I just wanted to follow up to see if you figured out how to disconnect the radio remote wires.
wow, my post was almost a year ago! sorry =/ , i didn't bother trying to fix it after i got stuck at that point (since i never got an answer from anyone). i had a lot going on, and my light is still on :) not to mention i don't have a scan tool to erase/read codes. if i remember correctly though, i may not have even safely removed all the 'reserve power' in the first place, cuz all i did was disconnect the battery; after reading up on AllData at my job, i was supposed to remove a fuse or relay too i believe.. so it's a good thing i didn't bother with it then. Good luck, and let me know if you got it working!
For the record - I'm not a dude! Sedan Revolution # 99 -- Waiting on a location/funds 2 start my Custom Tail Light Project.
kris4christ2 is offline
Old 07-01-2011, 11:11 PM   #32
kris4christ2
Fan#: 59197
Originally Posted by YellerZX3 View Post
Nice write-up. I've removed the column from my car twice (need to do it again to lineup the steering wheel).
how do i disconnect the steering wheel controls in the picture i posted?
Old 08-28-2011, 06:14 PM   #33
lumr002
Fan#: 89314
What I Drive: 2001 Red Ford Focus
FF Reputation: 1 lumr002 Good Standing Member
Great Post
2001 Ford Focus SE Station Wagon. Hey, I used your instructions to replace my clockspring because my turn signals would not cancel. Sure enough, the black plastic tab on the clockspring that cancels the turn signals was broken off. Using your instructions, it took me only 45 minutes and that was because it was on a hot day and I took some rest breaks. Also used the Ford Technical Service Bulletin (TSB) #04-5-5 which indicates that a 9mm spacer has to be installed to prevent the problem from reoccurring. Bought the Clockspring from O'Reilleys and the spacer from the Ford dealership. Spacer costs $20 at Ford. Great instructions and great pictures....THANKS!!!
lumr002 is offline
Old 04-24-2013, 01:32 AM   #34
FordFocus2002
Fan#: 113754
What I Drive: 2002 Green Ford Focus LR (MK1)
FF Reputation: 1 FordFocus2002 Good Standing Member
Anyone know how to get the steering shaft back up mine has slipped back and I can not get the steering wheel back on.
FordFocus2002 is offline
