Speedometer jumping - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-22-2006, 12:32 AM   #1
nickouellettesvt
nickouellettesvt's Avatar
Fan#: 33575
What I Drive: 2002 focus svt
FF Reputation: 2 nickouellettesvt Good Standing Member
Speedometer jumping
I noticed today that my speedo is jumping wildly from like 40mph-65mph, then when I get to 90mph its drops to 80 then back to 90. Whats up with that? is it an ECU, or the wiring in the speed sensor in the tranny?
My formally owned SVT was repoed
nickouellettesvt is offline
Old 09-22-2006, 09:24 PM   #2
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
Let's say you're doing 60 and the speedo drops to 40. Will it stay at 40 for some period of time (even if it's only a few seconds), or does it just drop and instantly return. Where I'm headed with this is I would suspect wiring/connections problem if the problem corrects instantly, some sort of component failure if the problem lasts for a period of time.
Often wrong but never in doubt.
Blurvfocus is offline
Old 09-22-2006, 09:42 PM   #3
FocusInAlaska
FocusInAlaska's Avatar
Fan#: 18038
What I Drive: 2004 Ford Comp. Orange SVT Focus
FF Reputation: 5 FocusInAlaska Good Standing Member
Sounds like the Vehicle Speed Sensor (VSS). Check the forums for this...
(been there, done that)
04 SVT Focus
"lunch box" muffler delete
15.35 @89mph, 2.29 60', 9.90 1/8 (100% stock)
FocusInAlaska is offline
Old 09-23-2006, 01:32 AM   #4
nickouellettesvt
Fan#: 33575
yea its an intstant jump...so the vss is the sensor that connects in to the tranny...?
Old 09-23-2006, 03:33 AM   #5
FocusInAlaska
Fan#: 18038
It's mounted on the top of the bellhousing, drivers side. It's almost impossible to see.
Having the speed sensor go out seems to affect the ECU as well.
04 SVT Focus
Old 06-07-2013, 10:00 PM   #6
Nerlyx
Fan#: 80937
What I Drive: 2003 CD SILVER SVT #1457
FF Reputation: 1 Nerlyx Good Standing Member
Got the same problem, replaced the sensor, didn't solve the problem
I don't know what to think.
Did Ford dealership sell me a bad sensor?
Or Is it bad wiring?
Or Is it my forward drive side wheel speed sensor that is going crazy?
Tomorrow I should be back with a scan of the ''Check engine'' code.
Thanks for the help. Driving to work is getting very sketchy...
Here's my story:
It all begins when my forward driver side brake seized. I removed my caliper for two days, lost a lot of brake fluid. Re-installed the caliper, fulled my reservoir, installed new brake pads. Compressed the piston, fluid spilled out of the reservoir. Cleaned as much as I could with what I had left of brake cleaner. Then re-installed the wheel, was trying to go to fast so I forgot to torque the nuts... Went for a test ride, heard crackling sound, drove with that sound for a minute before I realized what was going on. Torque the wheel properly, then I drove 45min to my parents' house, brake is still a little sticky after a hard braking... but no big deal. Rinsed the area around the brake fluid reservoir (with water- yeah, stoopid, I know). On my way back home, got the jumping speedometer, especially at low speeds (30mph +/- 10mph). Cleaned the connector and plug, didn't work. Replaced the plug, didn't work. And here I am. (Believe me or not, I really tried to keep the story short)
Nerlyx is offline
Old 06-08-2013, 11:36 AM   #7
TheSheerOg
Fan#: 96730
What I Drive: 2007 Black 1.8 Focus Sport S
Points 759, Level 14
Points: 759, Level: 14 Points: 759, Level: 14 Points: 759, Level: 14
Level Up 59% Completed
FF Reputation: 1 TheSheerOg Good Standing Member
Had the exact same problem, and replacing the speed sensor completely sorted it, i would check that first.
TheSheerOg is offline
Old 06-08-2013, 11:42 AM   #8
Nerlyx
Fan#: 80937
Which sensor? VSS or wheel speed sensor?
Because I've already replaced the VSS. (the one connected to the transmission)
Nerlyx is offline
Old 06-08-2013, 11:43 AM   #9
TheSheerOg
Fan#: 96730
Ah woops VSS, sorry Nerlyx i was replying to OP, didnt realise how old this thread was !
Old 06-08-2013, 12:09 PM   #10
Nerlyx
Fan#: 80937
Hehe no worries, good to know that it replacing VSS solved the problem for one more of you... it reinforces my idea that I received a bad sensor from ford.
Nerlyx is offline
