European Spec Tails - MADE SIMPLE!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-16-2006, 04:59 PM   #1
Darth Focus
I miss my Turbo SVTF
Darth Focus's Avatar
Fan#: 6849
What I Drive: 1988 Mazda 323 GTX
FF Reputation: 1 Darth Focus Good Standing Member
Buy-Sell-Trade Rating: (8)
First, let me say I did a lot of reading and it was almost 100% useless to me, so let me break it down...
1) Remove panels, carpet, sub box, etc. to make access to the drivers side quarter panel (in the trunk). You will see two plugs, a gray and blue.
2) In the blue plug is a green/ black wire - cut it after the plug. Thats for reverse and you wont need it for the tails (you will need it when you add a lower mount reverse light later).
3) Remove tail lights.
4) At the gray plug, find the green/ yellow wire, splice in and add TWO long sections of wire. Run each wire to the tail lights. I make a small hole in the rubber grommet with the tail light harness (under the tail light that is now removed). Run your wire out to each light.
5) On the tail light plug, cut the blue wire. Make sure you leave as much room as possible to splice the blue wire later.
6) The wire you ran to the tail lights goes to the SOCKET SIDE of the blue wire. You now have parking lights/ brake. Do this for each side.
7) Now, at the two pin reverse plug, cut the green/ black wire and use some spare wire to exten a wire between the green black wire from the socket to the blue wire you cut in step (5).
8) You now have independant turns.
9) Next, on the brake/ park socket, cut some of the twist locking tabs off until the socket fits into the euro light. It wont fit perfect, but it'll go in place and mont pop out. When you put the light in, the body of the car will limit movement. For the turn socket, the euro hole is too big so you can just stick the socket in and let it chill, or get a euro blub holder, and modify your US plug to plug in. All you have to do is cut away the black outer part so you just have pretty much the white square with nothing around it. Then, it just slides right in place. Holds just fine.
Thats it....all you have to do is run ONE wire...not a wire from the front, or anything else. Everything is done at the very back.
NOW! If you want to keep your US lights and go euro turns....do all the above mentioned stuff (sockets dont need to be modified, obviously) and just add an amber blub in place of the clear reverse blub. FREE EURO LIGHT MOD!!!
..and there you have it.
Russ Rudez
1988 Mazda 323 GTX; 1 of 1,243 Imported
AEM CAI, VJ11 Turbo @ 20psi, 2.5" IC Pipes,
Corksport IC, CFDF Clutch, 2.5" Turboback, Konis,
Suspension Tech Springs, 22mm Rear Sway, + More.
Darth Focus is offline
Old 09-16-2006, 05:04 PM   #2
Darth Focus
Fan#: 6849
...also, Id like to mention, this would make an excellent sticky!
Russ Rudez
Old 09-16-2006, 05:46 PM   #3
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
What I Drive: 2003 TwiBlue 2.3 ZX3
FF Reputation: 15 Lil PZEV Great Standing Member
Buy-Sell-Trade Rating: (14)
Added it to the Complete How-to Archive, thanks Russ.
Lil PZEV is offline
Old 09-16-2006, 07:57 PM   #4
Darth Focus
Fan#: 6849
Very good, I'll take it back apart and associate pictures with each step...
Russ Rudez
Old 09-16-2006, 08:03 PM   #5
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
Oh even better. Well it's linked to this thread, so any changes and it'll still link back here like it should.
Lil PZEV is offline
Old 09-16-2006, 08:10 PM   #6
Darth Focus
Fan#: 6849
Right on. I only wish I had a how-to before I did it. The info I did find, people were running wires all over the car - I thought, thats just too difficult, I only have so much wire, there has to be a better way. Sure enough...
Russ Rudez
Old 09-16-2006, 11:39 PM   #7
arrestmespi
Fan#: 27586
What I Drive: '04 Mazdaspeed Mx-5, '72 M35A2
FF Reputation: 27 arrestmespi Great Standing Member
it was very easy to do, I wonder if I can get some euro spec sedan tails
arrestmespi is offline
Old 09-17-2006, 01:42 AM   #8
Darth Focus
Fan#: 6849
They do make em...
Russ Rudez
Old 10-09-2006, 01:44 AM   #9
mrbrice
mrbrice's Avatar
Fan#: 22151
What I Drive: 2001 Silver Frost ZX3
FF Reputation: 1 mrbrice Good Standing Member
sorry to bring back a dead thread
...but i'd like to do this and keep the reverse lights? is there any way to wire up my '01 zx3 tails to make the reverses both turns and reverse?
"If you can't annoy somebody with what you write, I think there's little point in writing."
~ Kingsley Amis
R.I.P. 2000 Harvest Gold Metallic ZTS
mrbrice is offline
Old 10-10-2006, 09:43 AM   #10
joel22484
Fan#: 39476
What I Drive: 07 Liquid Grey ZX4
FF Reputation: 1 joel22484 Good Standing Member
any pics darth?
joel22484 is offline
