Old 09-13-2006, 10:47 PM   #1
SlammedZX3WI
Fan#: 36471
What I Drive: 2002 Ford Focus ZX3
FF Reputation: 1 SlammedZX3WI Good Standing Member
MY door handles aren't opening the car doors
Ok, my passenger door went out about mid July. And then the last couple of days, I've noticed my drivers side door was getting tougher and tougher to open. Well, tonight when I was leaving the campus, I went to open my door and the handle just came out...not off...came out. And since my f'n pass. door is broken as well, I had to climb through my f'n hatch.
I noticed that I can open and close the drivers side door from the outside as long as I don't lock it. IF I do lock it, I can't open it from the outside. And If I unlock it from the outside, It still wont open...(Has to be opened from the inside)
it's really c'ed up
I tried spraying some PB blaster in it...and it did no good
1)Where do I spray the lube?
2)Do you have to work it in or what?
3)Is this a recall thing...I see ALOT of this on here
Thanks
/f'n pissed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'...this is because I can spell confusion with a K and I can like it...It's to dying in anothers arms...and why I had to try it...It's to Jimmy Eat World...and those nights in my car...'
SlammedZX3WI is offline
Fan#: 1
Old 09-14-2006, 04:09 PM   #2
CowboyCasper
CowboyCasper's Avatar
Fan#: 38717
What I Drive: 2001 White ZX3
FF Reputation: 1 CowboyCasper Good Standing Member
Pop off the interior door panel, and tighten all of the internal screws, then lube with a silicone based spray lube.
I had a similar problem with my passenger side door handle. The insides just came loose.
White 2001 ZX3
17" FRPP White Rally Wheels, KW Cup Kit (1.6"), Progress 22mm Rear Sway, Short Ram Intake w/K&N Cone, Steeda 65mm TB, Ported 2k Manifold, FRPP 9mm Wires, MAC UDP, Clear Markers, OBX 4-1 Shorty Header, OBX ORP, FS Flex, 2nd Gen. MBRP Exhaust, FS/SCT Multi Chip
CowboyCasper is offline
Old 09-14-2006, 04:45 PM   #3
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
What I Drive: 2012 Sonic Blue SE Sport 5 Spd
FF Reputation: 43 Duffman355 Great Standing Member
there is no recall on door handles, but over time, many focus owners do experience some type of trouble with their door handles.
ST Crew #11 / SSR #5
Official Mayo Hater #1
Randomie's Lover #8
Duffman355 is offline
Old 09-14-2006, 04:47 PM   #4
DJ Lukdogg
DJ Lukdogg's Avatar
Fan#: 38235
What I Drive: 2006 Classic Silver Scion Tc
FF Reputation: 7 DJ Lukdogg Good Standing Member
TO: All U.S. Ford and Lincoln Mercury Dealers
SUBJECT: Safety Recall 05S27: Supplement #2
Certain 2000 - 2005 Model Year Focus 4-Door, 4-Door Wagon, and 5-Door Vehicles Originally Sold In, Or Currently Registered In Corrosion States
Rear Door Latch Corrosion
REASON FOR THIS SUPPLEMENT
This bulletin is being re-issued with the following revisions:
The population of affected vehicles is being expanded to include certain 2003 through 2005 MY vehicles.
Some of the affected 2005 vehicles had the lower rear door seal installed during production. This safety recall still needs to be performed but it is not necessary to install a new lower door seal if one was installed in production.
AFFECTED VEHICLES
All 2000 - 2002 model year Focus 4-Door, 4-Door Wagon, and 5-Door vehicles built at Wayne Assembly Plant and originally sold in, or currently registered in corrosion states.
All 2002 model year Focus 4-Door, 4-Door Wagon, and 5-Door vehicles built at Hermosillo Assembly Plant and originally sold in, or currently registered in corrosion states.
All 2003 - 2004 and certain 2005 built through January 26, 2005, Focus 4-Door, 4-Door Wagon, and 5-Door vehicles built at Hermosillo and Wayne assembly plants and originally sold in, or currently registered in corrosion States.
The affected vehicles were originally sold in, or currently registered in, the following states and Canadian Provinces:
US States: Connecticut
Maryland
New York
Delaware
Massachusetts
Ohio
District of Columbia
Michigan
Pennsylvania
Illinois
Minnesota
Rhode Island
Indiana
Missouri
Vermont
Iowa
New Hampshire
West Virginia
Maine
New Jersey
Wisconsin
Canadian Provinces: New Brunswick
Nova Scotia
Prince Edward Island
Newfoundland
Ontario
Quebec
Affected vehicles are identified in OASIS. In addition, for a list of vehicles assigned to your dealership, visit https://web.fsavinlists.dealerconnection.com. This information will be available on November 9, 2005.
REASON FOR THIS SAFETY RECALL
All rear door latches on 2000-2004 and some rear door latches on 2005 model year 4-door, 4-door wagon, and 5-door Ford Focus vehicles in recognized high corrosion areas of North America may experience corrosion in the pawl pivot area preventing proper engagement of the pawl into the catch. The customer may experience difficulty closing the rear door that may eventually progress to a point where the rear door may not latch properly. If not latched properly, the door may open while driving.
SERVICE ACTION
At no charge to the vehicle owner, dealers are to inspect, clean, and lubricate the rear door latches, install a lower rear door seal and informational label to the rear doors on all the affected vehicles. As a courtesy maintenance, dealers will also clean and lubricate the front door latches even though the front door latches are not part of this recall.
Note: Some 2005 MY vehicles were built with the door seal. Do not remove the existing door seal but do complete the rest of the service procedure.
If a rear door latch does not pass the prescribed inspection procedure as outlined in Attachment III, it will be replaced. A replacement latch must still have the cleaning and lubrication procedure performed using the approved Door Latch Repair Kit.
This recall must be performed on all of the affected vehicles in your new inventory as well as vehicles that have been delivered to customers.
PLEASE NOTE:
Federal law requires dealers to complete any outstanding safety recall service before a new vehicle is delivered to the buyer or lessee. Violation of this requirement by a dealer could result in a civil penalty of up to $5,000 per vehicle. Correct all vehicles in your new vehicle inventory before delivery
DJ Lukdogg is offline
Old 09-14-2006, 05:17 PM   #5
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
What I Drive: '02 Sonic Blue SVT Focus, '03 Wagon
FF Reputation: 34 WuNgUnSVT Great Standing Member
It's my belief that the interior door handle mechanics need to be lubed every year to avoid any problems...
Originally Posted by MattyKrackSVT View Post
...go threw your posts and see who can't spell retard...
WuNgUnSVT is offline
Old 09-15-2006, 01:57 AM   #6
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Memberpenguin Excellent Standing Member
"need to be lubed every year to avoid any problems..."
Are you talking about the stuff inside that requires removal of the door panel, or just to stuff that can be reached where the door latches?
penguin is offline
Old 09-15-2006, 05:10 PM   #7
SlammedZX3WI
Fan#: 36471
And this has worked for you???
I sprayed some PB Blaster an then a normal lube....and the drivers side door works now, but the pass. is f'ed!
Old 09-16-2006, 07:36 AM   #8
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
Yes, you have to pull the inner door skin off to get to it...
It's basically cause by the failure of the mechanism to fully return to the home position...and worse yet, the mechanism is designed in such a way that the outer handle is single action, meaning it will pull the latch, de-activating the retaining hook, but it can not return it back to it's normal position...it relies on a spring to do so.
You'll probably notice some 'play' in your outer handle when this is occuring...
And it worse cases, the door won't latch shut properly, leaving it open...
Old 09-17-2006, 08:26 AM   #9
KAG
Fan#: 23149
What I Drive: 2005 ZX5 SE
FF Reputation: 1 KAG Good Standing Member
DJ Lukdogg - Thanks for posting the info.
KAG is offline
Old 09-17-2006, 01:09 PM   #10
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I had this happen to me last winter (and now my passenger door is starting to show signs of it as well), all I did was pop out the inner panel and sprayed the latch on the inside of the door with some WD-40 and then pushed it with a screwdriver until it started to move on its own. I was to the point where I'd leave my window down enough that I could reach inside and pull on the latch...definite pain-in-the-ass when this happens.
SkaAddict is offline
